shadows in the freecad viewport
yorik
Site Admin
Re: shadows in the freecad viewport
Postby yorik » Fri Jul 19, 2019 3:10 pm
Yes it's realtime... you can change the light direction on the fly (last line of code above).
It works like this: to produce shadows, all the objects that must receive and cast shadows in your coin scene must be placed inside a SoShadowGroup, and there must be one ShadowDirectionalLight in that same SoShadowGroup (there re other types of shadow-casting lights available too). You can also add a SoShadowStyle inside, which allows to turn shadows on/off:
https://grey.colorado.edu/coin3d/classS ... Group.html
That's basically what the OfflineRenderingUtils.embedLight does: You give it a coin node/graph, and it embeds it inside a SoShadowGroup.
Only, the FreeCAD viewport doesn't have tools to replace the scenegraph. This would probably cause some problems too, as some tools likely wouldn't find their children anymore. But it would be cool to allow to add a SoShadowGroup to the main view. Need to look at how to do that correctly..
wmayer wrote:@Werner, any idea how we could work towards that?
So what the above script does is 1) create a blank viewer (which has no connection with FreeCAD tools and view providers), 2) build a coin scenegraph from the visible objects (so far I couldn't make it work to simply copy the main scenegraph, not sure why) 3) embed that scenegraph in a SoShadowGroup, 4) set the viewr's scenegraph with that scenegraph.
paullee
Postby paullee » Fri Jul 19, 2019 3:52 pm
Hi, error running the script ?
import OfflineRenderingUtils
ModuleNotFoundError: No module named 'OfflineRenderingUtils'
bitacovir
Postby bitacovir » Fri Jul 19, 2019 7:11 pm
It works fine for me. just copy and paste on the Python console.
But the functions of standard views (top view, front view) in the toolbar are not working, anymore.
Version: 0.19.17433 (Git)
Hash: 125380ddd9a1fdeb45ffc736040dad1f6343daa4
Python version: 3.6.6
Qt version: 5.6.2
::bitacovir::
My Blog
Mini Airflow Tunnel Project
bitacovir
Postby bitacovir » Fri Jul 19, 2019 7:19 pm
other examples...
::bitacovir::
My Blog
easyw-fc
Postby easyw-fc » Fri Jul 19, 2019 7:40 pm
the same for me on win and on linux
OS: Linux Mint 19.1 (MATE/mate)
Version: 0.19.
Python version: 3.6.8
Qt version: 5.9.5
yorik
Site Admin
Postby yorik » Sat Jul 20, 2019 1:02 am
Ah my bad, forgot to add that file (OfflineRenderingUtils) to the PPA recipe... Will do right now
paullee
Postby paullee » Sat Jul 20, 2019 1:15 am
Looks great, black & white? Texture works?
I am on fedora 30, maybe I need to search for the package.
Site Admin
Postby wmayer » Sat Jul 20, 2019 2:55 pm
This actually shouldn't cause problems because view providers usually search underneath their root separator. And if any function needs to search for nodes of other objects (like the body feature) it shouldn't assume any fix order of how the nodes are organized but is supposed to use an SoSearchAction.
Btw the clipping plane or axis cross functions also change the graph structure at runtime and I have never seen a problem.
from pivy import coin
sotype=coin.SoType.fromName("SoShadowGroup")
shadow=sotype.createInstance()
shadow.precision.setValue(1)
shadow.quality.setValue(1)
sotype=coin.SoType.fromName("ShadowDirectionalLight")
light=sotype.createInstance()
light.intensity.setValue(200)
light.direction.setValue(-1,-1,-1)
view=Gui.ActiveDocument.ActiveView.getViewer()
root=view.getSceneGraph()
# get the third node of the root (or search for SoSeparator)
scene=root.getChild(2)
root.removeChild(scene)
shadow.addChild(light)
shadow.addChild(scene)
root.addChild(shadow)
paullee
Postby paullee » Sun Jul 21, 2019 12:39 am
Finally found it is @yorik's works can't find elsewhere :)
But seem the current AppImage is not latest compare to @bitacovir's... FreeCAD_0.19-17360-Linux-Conda_Py3Qt5_glibc2.12-x86_64.AppImage
  1. Running the Latest script Downlaod from /FreeCAD on 17360 AppImage return errror about <!DOCTYPE html>
  2. Running the 'original script' on 17360 AppImage return error about embed light
Seem need to wait ...
  File "/run/media/paullee/Home_1/paullee/Downloads/FreeCAD_0.19-17360-Linux-Conda_Py3Qt5_glibc2.12-x86_64/squashfs-root/usr/Mod/Arch/OfflineRenderingUtils.py", line 7
    <!DOCTYPE html>
SyntaxError: invalid syntax
>>> objs = [o for o in FreeCAD.ActiveDocument.Objects if o.ViewObject.Visibility == True] # gather visible objects
>>> cam = FreeCADGui.ActiveDocument.ActiveView.getCamera() # gather the camera position
>>> s = OfflineRenderingUtils.buildScene(objs) # build the coin scene
NameError: name 'OfflineRenderingUtils' is not defined
>>> rn = OfflineRenderingUtils.embedLight(s,(1,1,-1)) # embed the wholescene in a ShadowGroup, add directional light
>>> light = rn.getChild(0) # get a ref to the directional light for later
NameError: name 'rn' is not defined
>>> v = FreeCADGui.createViewer() # create an empty 3D view in FreeCAD
>>> v.setCamera(cam) # set the camera
>>> vv = v.getViewer().setSceneGraph(rn) # set our scene as its scenegraph
>>> light.direction = (-1,-1,-1) # change light direction
AttributeError: module 'OfflineRenderingUtils' has no attribute 'embedLight'
yorik
Site Admin
Postby yorik » Sun Jul 21, 2019 8:24 pm
Wow that's audacious :D Great! Thanks!!! It works and it's SERIOUSLY COOL:
Screenshot from 2019-07-21 17-21-30.png (177.29 KiB) Viewed 174 times
This is the working FreeCAD view, everything still selectable and updatable. Only a few issues like new objects not added to the shadow group. But we're getting there...
File "/run/media/paullee/Home_1/paullee/Downloads/FreeCAD_0.19-17360-Linux-Conda_Py3Qt5_glibc2.12-x86_64/squashfs-root/usr/Mod/Arch/OfflineRenderingUtils.py", line 7 <!DOCTYPE html> ^
There is something VERY wrong there... :shock: I guess the packaging went pretty bad on that build. The error about embedLight is probably that the version of OfflineRenderingUtils there is too old...
